Proportional valves with onboard electronics
VED03M proportional control valves with onboard electronics come preprogrammed from the factory or can be programmed from a laptop computer or Flash card equipped PDA.
Available in six flow rates from 1 to 9 gpm. Three spool-centered options and five metering options results in 90 possible combinations. Rated to 5000 psi, equipped with 12/24 Vdc solenoids, and use standard seven-pin connectors at the system end.
Continental Hydraulics
(952) 895-6400
www.continentalhydraulics.com
