FC and FI safety valves supply an electrical on-off output to detect the position of the spool/poppet of the valve and its hydraulic status. FC version comes with mechanical microswitch and FI version comes with inductive proximity sensor. Available on direct/pilot operated valves in subplate/cartridge executions, they cut off, in emergencies, line of hydraulic power to an actuator. T<V certified to EN201, EN693, En982, and EN12622.
Atos Systems
(951) 637-2497
www.atos.com
