Engineered manifolds
Engineered manifolds allow for optimum system performance by reducing system design and maintenance costs 25 to 45%. Steel, brass, stainless steel, aluminum, or Monel designs available in 1/8 to 2 in. sizes. For use with hydraulic fluid, oil, air, refrigerant, water, etc. Manifolds reduce leak points and control system pressure.
Fluid Line Products Inc., (440) 946-9470, www.fluidline.com
