Air valve manifold system
Plug-in style CD26-PL air valve is 26 mm wide for flows to 1.01 Cv. Pneumatic and electrical connections done on base plate. Manifold threaded ports come as NPT or ISO-G (BSPP). Valve operates from single or double solenoid and double 3/2 valves to allow two functions from same position. Multi-pin plug version with D-sub connector is available. Bus protocols include Profibus DP, CANopen, DeviceNet, Interbus S, and ControlNet, as well as Ethernet IP. Bosch Rexroth Corp., Pneumatics Technology Group, (859) 254-8031, www.boschrexroth-us.com
