Block manifold system
Johnson Block manifold system uses standard blocks that are coupled together to create custom manifolds. Blocks are built from 6061-T6 aluminum and are rated for 3500 psi. Blank modules are stocked for building circuits that can be used with particular valves and suit a variety of flow paths and valve models.
Datum-A-Industries, (800) 806-6162, www.datum-manifolds.com
