Pneumatic manifolds
Single and multi-station manifolds are available for use with company’s Oxygen Clean series electronic valves. Manifolds offer single- or double-sided mounting in compatible electroless nickel plated brass material, and feature 18-in. NPT input ports and #10-32 outlets. Available in 1- through 12-stations, manifolds provide easy access for grouping valves, fittings, or other pneumatic components. They are ultrasonically cleaned and inspected in an enclosed controlled area with a High Efficiency Particulate Air (HEPA) filtration system.
Clippard Instrument Laboratory Inc., (888) 256-2178, www.clippard.com/oxygen-h
