Advertisement
Hydraulic rotary manifolds are designed for the transmission of hydraulic fluid, water, coolants, air and many other fluids. Every manifold can be equipped with an electrical swivel joint. They are available with up to 16 ports, continuous rotation, and 6100-psi max pressure. Surface treatments such as chrome, brass, and nickelplated are optional.
Young Powertech Inc
(610) 558- 0760
www.yptius.com
