Edited By Mary C. Gannon
The 410M series manifold accommodates 310 and 410 in-line solenoid valves. It enables mounting both 3-way and 4-way valves on the same manifold, with the 310 series mounting orientation determining the NC or NO function. Manifolds are available in 2, 4, 6, 8, or 12 station lengths. The 310 and 410 are 18-in. ported 3-way and 4-way direct acting solenoid valves. They have a 0.12 and 0.14 CV flow rate, respectively, and are rated for air from vacuum at 28-in. Hg to 125 psig.
Humphrey Products Co., (269) 381-5500, www.humphrey-products.com
