Series SV and VQC solenoid valves and manifolds are ControlNet and CANopen compatible. IP67 compliant EX250 adaptor reduces need for wiring between conventional serial interface units and valves installed in confined spaces. Accomodates 32 solenoid valve outputs and 32 sensor inputs. Self-diagnostics function monitors voltage and sensor power supply overcurrent cut-off, with status sent to master PLC.
SMC Corp. of America,
(317) 899-4650,
www.smcusa.com
