Series 58 sub-miniature two-way, normally closed valves feature in-line barbed fittings for a small size and easy connection. Rated 3.5 or 0.9 W for use on circuit boards and miniaturized components with pneumatic outputs. Size of 2 1 5/8 in. Maximum operating pressure to 300 psi and burst pressure to 1500 psi. Operating temperature of -5° to 122° F. Coil voltage is 220 Vac or 2 to 150 Vdc.
Peter Paul Electronics Co. Inc.,
(860) 229-4884,
www.peterpaul.com
