Monitored soft start dump valves
Monitored soft start dump valves limit risks during initial pressurization by allowing controlled increase of pressure to downstream equipment, thereby reducing possible damage from rapid pressurization. Integral micro switch monitors dump function to ensure valve in signaled position. Based on 1/2 in. pipe, they deliver high forward flow and dump flow capacity. Features maximum input pressure of 232 psi and minimum output of 43 psi.
IMI Norgren Inc., (303) 794-2611, www.norgren.com
