High-pressure valve
CRCB valve
CRCB valve
CRCB valve uses a solid seal located in the body instead of on the spool, eliminating seal blow out to valve's proof pressure of 300 psig. Valve is 10 mm wide and operates at pressure to 225 psig. Features a solenoidoperated internal pilot, 8 msec response time, 0.1 Cv, and 0.8 W consumption. Available for line mounting or on manifolds.
Humphrey Products Co., (269) 381-5500, www.humphrey-products.com
