Direct-acting solenoid air valves
Series 315 multi-purpose 3-way and 415 five port, 4-way valves solenoid valves are 19-mm wide and offer flows to 0.42 Cv, which is 35% higher than poppet valves. Lip seal design uses air pressure in valve to assist spring in making a tight seal and high flow. They feature 1/8 in. NPT ports, operating pressure of 28 in. Hg to 125 psig, 5-W coil, ac and dc voltage, and NEMA 4 rating. Both are designed for inline and manifold mounting.
Humphrey Products Co., (269) 381-5500, www.humphrey-products.com
