VA01 valves for vacuum applications are used in pick-and-place systems. Featuring 5 msec solenoid response time, 10-mm wide valves eliminate two three-way valves when centralized vacuum systems are used with part blow-off. Poppet control valve features a vacuum valve and adjustable blow-off valve with atmospheric-release mechanism that reduces variation of breaking time and overshoots blow-off and cycle time. They can be mounted as a single valve on multiple valve station manifolds.
Parker Hannifin Corp., Pneumatic Div., (269) 629-5000, www.parker.com
