Four-way air valves
Moduflex valves combine two, independently operated 4-way valves into one valve body. They can be combined with other dual 3-way or single 4-way valves of either Size 1 or Size 2, without transition kits. They are available in 24 Vdc solenoid or air pilot operated versions with a universal manual override. Universal manual override is available as locking/non-locking, and can be changed in the field to non-locking override only.
Parker Hannifin Corp.,
(269) 629-5000,
www.parker.com/pneumatics
