Air valve manifolds
Heavy-duty MultiMach valve manifolds feature automatic electrical connections. Electrical signal between valves is relayed from one valve to the next by gold-plated contacts connected to an electrical board. Three sizes of 1-16 valves are interchangeable on the same manifold. Integral tube fittings are sized at 5/32, 1/4, and 5/16 in. for flows of 0.2, 0.5, and 0.8 Cv, respectively. Valves are rated to IP65 and powered by 24 Vdc with 0.6 W consumption.
Metal Work Pneumatic USA Inc., (817) 701-4000, www.metalwork.it
