Moduflex dual valve combines two, 4-way valves into one valve body. It features two independently operated valves in the Size 1 valve body. It can be combined with other dual 3-way or single 4-way valves of either Size 1 or Size 2, without transition kits. Moduflex valves are available in 24 Vdc solenoid or air pilot operated versions with universal manual override, which is available as locking/non-locking, and can be changed in the field to non-locking override only.
Parker Hannifin Corp., Pneumatic Div., (269) 629-5000, www.parker.com/pneumatics
