Line of condensate drain valve assemblies are designed for use in compressed air systems for critical moisture drainage. Air-operated models incorporate a straight-through design with fewer components. This provides leak-tight sealing and non-clog operation for lower cost and minimal maintenance. Solenoid-operated versions are smaller and offer longer life in high-temperature, high-humidity applications. Both versions come with standard timer range, elastomer, and voltage.
ASCO, Div. of Emerson, (800) 972-2726, www.ascovalve.com
