Ultramat zero air-loss condensate drain valve eliminates moisture without pressure loss. It can be installed in restricted spaces and opens only when necessary and closes before compressed air is lost. Internal reservoir and flow channels reduce possibility of blockage and minimize fouling of the drain valve seat, allowing more thorough processing at a downstream oil/water separator. It can provide energy efficiency improvements of 20 to 50%.
Donaldson Co. Inc.
(800) 543-3634
www.donaldson.com
