Hi-Cyclic Magna-Cycle pneumatic, 4-way, 2-position directional control valves are air pilot actuated. They contain adjustable permanent magnets in both pilot chambers that detent and hold the spool in one of two positions until building pilot pressure exceeds the holding force of the magnet. Adjustment screws allow pilot pressure between 20 and 80 psi to actuate valve to opposite position. Models include internal pilot connections, external pilot connections, and mixed pilots.
Lexair Inc.
(859) 255-5001
www.lexairinc.com
