Parallel Check Valve
Dual-Check pneumatic valve assembly with two parallel check valves can be manually overridden with a single button or with an internally plumbed air pilot. It prevents load and drift and provide rapid stopping of a load. It operates in pressures from 15 to 150 psi and have flow capacities of 1.1 to 1.9 CV. It provides multiple position control and does not require lubricated air. Self-cleaning ball seal provides long product long of more than 100 million cycles in test.
Aladco Engineering & Mfg. Inc.
(202) 544-5994
www.aladco.com
