AirLine type 8644 remote actuation and control system provides on/off pneumatic functions, analog and digital input/output modules, and Fieldbus connectivity in a single, DIN rail-mount assembly. It supports most pneumatic or electronic field devices. Supported Fieldbus interfaces include Profibus DP/FMS, DeviceNet, ControlNet, Interbus, CANopen, Ethernet, Ethernet TCP/ IP, Modbus, and Lonworks. Valve module uses 10- and 16-mm pilot valves (3/2 and 5/2 circuit functions) with flows to 700 lpm at pressures to 100 psi.
Burkert
(800) 325-1405
www.burkert-usa.com
