Pneumatic fittings, valves
Edited By Mary C. Gannon
NITRA pneumatic fittings and valves are for use with polyurethane and nylon tubing. ME and MS male straight and male elbows come in 532 and 14 in. MEL long male elbow fittings come in 532 and 14 in. with #10-32 threads. MSR push-to-connect male straight round fittings come in ten sizes ranging from 532 to 14 in. and 4 to 6 mm. HVU three-way hand valves come in seven sizes from 14 to 12 in. and 6 to 12 mm. CVU union check valves range from 532 to 38 in. and 6 to 8 mm. Stop valves range from 532 to 12 in. and 6 to 12 mm diameters. Tubing cutter is for use with 18 to 12 in. and 4 to 12-mm flexible plastic tubing.
AutomationDirect
(800) 633-0405
www.automationdirect.com
