Edited By Mary C. Gannon
Expanded B-Design fieldbus components include support for Sercos III and Ethernet/IP for HF03-LG, HF04, and CD01/02-PI valve manifold systems. Valve body sizes are 10, 15, 18 and 26 mm wide. Sercos III features up to 32 outputs per manifold. Up to four valve manifolds can be controlled from one bus module. EtherNet/IP features up to 48 inputs per manifold in addition to solenoid and discrete outputs. Up to four valve manifolds can be controlled by one bus module.
Bosch Rexroth Corp.
(859) 259-3417
www.boschrexroth-us.com/brp
