Edited By Mary C. Gannon
Dale series LF and LX high-flow inline-mounted poppet valves are available as 2-way in normally-open, normally-closed and pressure-controlled configurations. They are available in pipe sizes ranging from 38 to 212 in., with a 3.6 to 64.7 CV range. They do not restrict airflow at inlet or outlet, so they are suitable for applications where full flow is required. They reduce hammering, and have built-in speed control, for fast shifting or controlled shifting in either direction.
Ross Controls
(800) 438-7677
www.rosscontrols.com
