Wear-resistant seals
F-Treated FKM elastomers provide permanent surface treatment that will not dissipate with wear. F-Treat process provides a permanent low coefficient of friction surface on seals. Modification is present beneath the surface of the molded component so that if abrasion occurs, a modified low friction surface will always be present. Minnesota Rubber and Plastics, (952) 927-1400, www.mnrubber.com
