Flange seals
Flange seals
Hydraulic flange seals are manufactured from high-grade polyurethane, for aggressive and heavy duty applications. They provide added resistance to extrusion and compression set over a temperature range of –40° to 230°F and a pressure rating to 6000 psi. They fit SAE standard location groove on underside of the flange, and feature a custom manufactured rectangular cross-section. They are available in six sizes from 12 to 2 in.
Pirtek USA
(321) 504-4422
www.pirtekusa.com/service
