How dry is dry enough?
Understand the pressure dew point to determine the best dryer for your facility.
What is in this article?:
To learn more about air dryers, read our Fluid Power Basics chapter on the subject.
Desiccant dryers
Unlike refrigerant-based units, desiccant dryers use porous desiccant beads to remove moisture from untreated air. Three types of desiccant dryers are widely used in the market: heatless, heated purge, and blower purge.
Heatless desiccant dryers use desiccant material contained within two towers to adsorb moisture from the compressed-air stream. Unprocessed, compressed air flows through the drying tower. The air passes through a diffuser screen and is distributed uniformly through the  desiccant column. As air travels through the tower, the porous desiccant beads adsorb moisture, removing it from the air stream. This process generates heat, referred to as the heat of adsorption. The process typically raises air temperature by 15° to 20°F. The dry air, which can reach a pressure dew point of –40° to –100°F, exits the drying tower and travels downstream to the user’s equipment.
To remove the accumulated water from the desiccant, about 15% of the dry air emerging from the drying tower is channeled to the second, regenerating tower. In the regenerating tower, the air expands to atmospheric pressure as it moves over the desiccant beads. The dry, low-pressure air passes through the tower and collects moisture off the desiccant beads, aided by the heat of adsorption generated during the drying process. The towers switch from drying to regenerating in fixed intervals, letting one side continuously dry the process air while simultaneously regenerating the opposite tower.
Heated desiccant dryers — also referred to as heat reactivated or heated purge desiccant dryers — have a heater in the dryer’s regeneration circuit. This type uses a combination of heat and airflow to regenerate the desiccant adsorption beads.
In a heated desiccant dryer, untreated air from the compressor enters the drying tower and flows over desiccant beads. Similar to heatless dryers, the beads adsorb and remove moisture. Air exiting the drying tower can have pressure dew points ranging from –40° to –100°F.
While the drying tower treats compressed air, the opposite tower regenerates the desiccant. About 7% to 8% of the dried air is diverted for regeneration. This air passes through a heater, and the resulting extremely hot and dry air passes over the desiccant beads in the regenerating tower, liberating the moisture. The moist air is ultimately discharged through sound-attenuating mufflers. Given the energy costs associated with generating compressed air, heated purge dryers often cost less to operate than heatless dryers, as they use about 50% less compressed air for regeneration.
Heated blower dryers — also called blower purge dryers — do not require processed air to regenerate the desiccant in the regenerating tower. Instead, they rely on a dedicated blower that draws air from the surrounding environment.
The flow path to dry compressed air is the same as in the heated dryer configuration. Air enters the drying tower, flows across the desiccant, and discharges at the dryer outlet.
During regeneration, however, the blower draws air through a filter and sends it through a heater. The hot air travels into the regenerating tower where it is diffused, sent through the desiccant beads to extract moisture, recollected, and then exhausted through the purge-air outlet valve.
Thus, a notable difference between heated dryers and heated blower dryers is that blower purge dryers do not require 8% of the treated air for regeneration. The compressor’s total air capacity is available at the dryer outlet. A blower purge dryer that processes 500 scfm at the dryer inlet will have 500 scfm available at the dryer outlet, unlike other desiccant dryers. Like other desiccant units, heated blower dryers produce pressure dew points in the –40° to –100°F range.
Heatless, heated, and heated blower desiccant models produce the extremely dry air needed for sensitive applications such as chemical and pharmaceutical processing, but they typically require a larger initial investment than refrigerated dryers. The heated blower model has the greatest up-front cost but is often the most efficient to operate because it does not use compressed air for regeneration. In contrast, the heatless model is the most affordable of the desiccant dryer designs. However, the cost of the purge air used for regeneration may ultimately result in a higher total cost of ownership over the life of the equipment, when compared to heated and heated blower dryers.
Heat of compression dryers
Heat of compression (HOC) dryers are the most energy-efficient types. HOC dryers are desiccant dryers that capture and recycle heat generated by an oil-free air compressor during the compression process. Most HOC dryers have two towers filled with desiccant and deliver full compressor capacity at the dryer outlet.
Compressing air produces a significant amount of heat. With conventional refrigerated and desiccant dryers, a water- or air-cooled aftercooler removes that heat, and compressed air is delivered to the dryer at approximately 100°F.
In HOC dryers, the hot compressed air ­— typically around 340°F — travels directly from the oil-free compressor to the regeneration tower. Air flows through the tower, removing moisture from the desiccant column, and exits as hot, wet air. This moisture-laden air then passes through an aftercooler, where it emerges at approximately 100°F. The full compressed airflow then travels through the drying tower and exits with little moisture and a dew point of approximately –40°F.
HOC dryers coupled with Class 0 oil-free air compressors are ideal for critical applications in food, beverage, chemical, and pharmaceutical industries. This designation ensures compressed air moving through the system is free of water, oil, and particulates to ensure the quality of the end product. While HOC dryers require a larger capital investment than refrigerated or conventional desiccant dryers, operating costs can be on par with a light bulb.
For more information on compressed-air dryers, visit www.ingersollrandproducts.com.
Selecting the right dryer
Every facility has unique needs and demands, so there is not a “one size fits all” dryer suitable for all applications. Refrigerated, desiccant, and HOC dryers all have a place. Consider these factors when determining which dryer is the best choice:
  • What dew point does the end-product or process require?
  • What is the initial cost of the dryer?
  • How much energy is required to run the dryer?
  • How will the dryer affect the facility’s annual operating costs?
  • What is the facility’s flow requirement?
  • Does the facility need full outlet flow from the dryer?
  • What type of air compressor will be used with the dryer?
  • How frequently is the facility running at partial versus full capacity?
It is important to determine how dry is “dry enough” for the application at hand. Once you’ve identified the minimum moisture content of the system, factor the performance, energy demands, and operational savings associated with each dryer type into the investment equation.;
Discuss this Article 0
Post new comment
(optional)
