A new iPhone app from In Situ Hydraulic Experts, a French hydraulic consulting company, is now available for download at the Apple Store. The app helps with unit conversions and equivalence values for hydraulic pumps, motors, and cylinders. It also helps you calculate motor and mechanical pump power.
As an example, fields are given for hydraulic pump technical specifications, such as displacement, rotational speed, volumetric efficiency, theoretical and actual flow, pressure, and hydraulic power. Users simply enter data, select calculate, and the app quickly displays solutions.
In Situ says this is the first of many fluid power iPhone apps it intends to release.
Visit the Apple Store here to download the app or visit In Situ for more details.
- Alan Hitchcox's blog
- The Old Timer Part 22: Don't Let Your Pump Go to Pieces
- Hydraulic fluids from the rain forest
- <a href="/penton_ur/nojs/login" class="ctools-use-modal ctools-modal-log_in" title="Log in to this site.">Log In</a> or <a href="/penton_ur/nojs/light/register" class="ctools-use-modal ctools-modal-register_light" title="Register at this site.">Register</a> to post comments
