The Old Timer Part 7: It’s Tough to Outwit the Night Shift
Making pressure setting tamper-proof is no easy task.
The Old Timer of Royal Oak, Mich., was a regular contributor to H&P years before we ever even heard of the internet. But most of his advice is just as ueful — and interesting — today.
So rather than leave his wisdom printed on pages archived in our storage room, I pulled out issues from the late 1980s and early 1990s and will reproduce relevant entries in this blog. Here is my seventh entry, which was originally published in the February 1988 issue:
It’s tough to outwit the night shift
One of our foundries had a complex sand moving system with pneumatically actuated rubber pinch valves to turn flow on and off. The valves operated at 45 psi; with no pressure, the valve was fully open; with 45 psi, the valve fully closed. At higher pressures, rubber bladders could break, mixing air with the sand and fouling the system. That was our problem: the operators always wanted to crank up the pressure.
 Our first fix was to set the master regulator and saw off the adjustment handle. The next day, we discovered that the night shift had cut a screwdriver slot into the handle stub so they could change the adjustment. Next, we tried a non-adjustable regulator, only to find it had been replaced by an adjustable model some time during the night shift. A couple of other attempts to lock the air pressure also were thwarted — and, of course, no one ever admitted to tinkering with the equipment.
I finally came up with what was essentially an alarm system. On a high and difficult-to-reach section of the air piping network, I installed a 50-psi relief valve and connected its outlet to an old-fashioned steam whistle. If someone turned up the regulator, the whistle blew immediately and called attention to the culprit.
The night shift guys gave up, but they still had the last laugh. They used the steam whistle as an adjustment guide. When their shift began, they’d turn up the regulator until the whistle sounded, then back down the adjustment until it stopped. That way, they had the maximum pressure that our system would permit.
Discuss this Blog Entry 23
kellie
on May 12, 2013
I'm still memorizing from you, but I attempt to achieve my targets. In light of the fact that then delight in perusing every last trace of the informative content that shows up on your blog .Keep come. Adored it! Sydney Punk Rock
kellie
on May 12, 2013
I read this article. I think You put a lot of effort to create this article. I appreciate your work. Beautiful graphics
kellie
on May 12, 2013
I wanted to leave a little comment to support you and wish you a good continuation. I want to encourage that you continue your great job. digital media news
kellie
on May 12, 2013
This is a fantastic post in an engaging line of substance, important way of carry this subject to dialogue. A debt of gratitude is in order regarding imparting this article, keep up the astounding work ! free directory submission
kellie
on May 12, 2013
This is my first time at your blog and I’ve really enjoyed looking around. I will come back again in the future to check out some of the other articles clash of clans hack
calvinbrock735
on May 12, 2013
Took me time to read all the comments, but I really enjoyed the article. It proved to be Very helpful to me and I am sure to all the commenters here! It’s always nice when you can not only be informed, but also entertained! removalists Brisbane
kellie
on May 13, 2013
You can write about the terms and conditions on the blog. You might chronicle it's spectacular. Your blog familiarly might thicken your fans. WordPress Themes
kellie
on May 13, 2013
I'm still memorizing from you, but I attempt to achieve my targets. In light of the fact that then delight in perusing every last trace of the informative content that shows up on your blog .Keep come. Free Wallpapers Online
kellie
on May 13, 2013
Nicely presented information in this post, I prefer to read this kind of stuff. The quality of content is fine and the conclusion is excellent. transport persoane colete anglia
kellie
on May 13, 2013
There are normally standards that must be met, for example having obtained a 2:1 degree classification. You may also be asked for work experience in your field. style
kellie
on May 13, 2013
You are making some very nice points in The Dark Annoying Orange | Annoying Orange. The way that you pass on your ideas is one of the reasons I love your writing as I do. Jasa SEO Murah
kellie
on May 13, 2013
You clearly know so much about the subject, you’ve covered so many bases. Great stuff from this part of the internet. Again, thank you for this blog. abiogenesis
kellie
on May 13, 2013
Awesome blog. I enjoyed reading your articles. This is truly a great read for me. I have bookmarked it and I am looking forward to reading new articles. Keep up the good work! RightFax API
kellie
on May 14, 2013
I want you to thank for your time of this wonderful read!!! I definately enjoy every little bit of it and I have you bookmarked to check out new stuff of your blog a must read blog!!!! vinilos infantiles
kellie
on May 14, 2013
wow, great, I was wondering how to cure acne naturally. and found your site by google, learned a lot, now i’m a bit clear. I’ve bookmark your site and also add rss. keep us updated. Free Instagram Followers
kellie
on May 14, 2013
This is a wonderful article, Given so much info in it, These type of articles keeps the users interest in the website, and keep on sharing more ... good luck. siti internet Trento
kellie
on May 14, 2013
You made some good points .I did a little research on the topic and found that most people agree with your blog Virtual Assistant India
kellie
on May 14, 2013
I really do not truly have much to say in response, I only wanted to comment to reply great work. Scalpmed
kellie
on May 14, 2013
A very good and informative article indeed . It helps me a lot to enhance my knowledge, I really like the way the writer presented his views. I hope to see more informative and useful articles in future. bathing suits
kellie
on May 14, 2013
Great tips and very easy to understand. This will definitely be very useful for me when I get a chance to start my blog. Cheap Fashion Jewelry
riesty
on May 25, 2013
very good information and I needed. hopefully gunabe still exist on the internet. http://www.leafletsareus.co.uk/leaflet-distribution-edinburgh.php
stellafin
on Jun 8, 2013
This is interesting and nice. I like it.
Fat Loss Factor
kellie
on Jun 17, 2013
I like this blog. Very helpful and very inspirational. Thanks a ton. It’ll help me a lot. serrurier lyon
Post new comment
(optional)
What's The Hitch Post?
Observations about fluid power and other technologies, technical writing, and unrelated topics
Contributors
Alan Hitchcox
Alan joined Hydraulics & Pneumatics in 1987 with experience as a technical magazine editor and in industrial sales. He graduated with a BS in engineering technology from Franklin University and...
Blog Archive
