Hydraulicspneumatics 2133 199006 Think First Fig 12
Think First, Then Troubleshoot — Chapter 9: Relief Valves
Sept. 11, 2013
When a hydraulic system has problems, it is common practice to first look at the pump. The pump is arguably the heart of almost every hydraulic system and, as such, has traditionally been blamed for almost every operating problem. Obviously this cannot be true, but when preliminary troubleshooting analysis focuses on the pump, a series of steps can pinpoint the specific problem and lead to the cure.
Chapter 9:  Relief valves
Figure 12 – Suggested troubleshooting procedure for hydraulic relief valves. Click on image for larger view.
The unsung hero of many hydraulic systems often is the relief valve.  The hydraulic relief valve’s contribution is extremely important because it limits the amount of power a system can generate.  The relief valve thus helps to ensure that intended system pressure will not e exceeded.  This pressure limitation helps avoid damage to other hydraulic components and the machinery or injury to workers.
The relief valve function helps establish the fact that hydraulics is a convenient and efficient method for transmitting power.  Mechanical and electrical power transmission systems cannot match the simplicity and low cost of the relief valve.
Table 1— System test for relief valves. Click on image for larger view.
Referring to Figure 12, the troubleshooter should install a pressure gauge at the upstream test point – if one is not already in place – to determine the maximum pressure at which the system will operate as controlled by the relief valve.  Many makes of relief valves provide a port in the valve to connect a gauge.
Figure 12 provides simple and quick means for determining if the problem is with the relief valve or elsewhere in the system.  If the troubleshooter determines that the problem is in fact with the relief valve, Figure 12 suggests possible causes of typical troubles.
Alan Hitchcox Blog | Editor in Chief
Alan joined Hydraulics & Pneumatics in 1987 with experience as a technical magazine editor and in industrial sales. He graduated with a BS in engineering technology from Franklin University and has also worked as a mechanic and service coordinator. He has taken technical courses in fluid power and electronic and digital control at the Milwaukee School of Engineering and the University of Wisconsin and has served on numerous industry committees.
