Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads 2014 04 2006 07 Eds
Pressure switch does triple duty
July 13, 2006
EDS 3000 compact pressure switch, from HYDAC Technology Corp. combines a pressure switch, digital display, and pressure transducer into a single instrument for monitoring and controlling pressure in fluid power systems.
The EDS 3000 compact pressure switch, from HYDAC Technology Corp., Bethlehem, Pa., combines a pressure switch, digital display, and pressure transducer into a single instrument for monitoring and controlling pressure in fluid power systems. The switch has a four-digit display and front that can be repositioned, which eliminates the need for adapters. Standard pressure ranges from vacuum to 9000 psi can be displayed in bar, psi, or mpa. One or two switching outputs with or without analog output are available.
For more information call (877) 464-9322, or visit www.hydacusa.com.
Electro-Pneumatic Pressure Regulator Provides High Level of Accuracy
April 18, 2024
Inclusion of electronic controls in the Proportion-Air QBX electro-pneumatic pressure regulator ensures accurate and repeatable pressure control.
Modeling Pressure Changes in Hydraulic Systems
Feb. 15, 2021
Here’s the math behind pressure changes in hydraulics.
