The D-Series double-acting air cylinders are now available with adjustable cushions to provide end-of-stroke deceleration at both ends.Part of the company’s NITRA line, these pneumatic cylinders have a 250-psi operating pressure and are interchangeable with other brands. Constructed with high-quality aluminum alloy, the cylinder’s magnetic piston can be used with solid-state or reed switches for rod-position sensing. Bores range from 1½ to 4 in. and strokes from 1 to 24 in. Models feature flange, rear clevis and rear pivot, side, and rod clevis mounting options.
AutomationDirect, 770.889.2858, www.automationdirect.com
