What is in this article?:
- Benefits of plastic connectors
- Connection options
Connection options
Connectors are designed to accommodate tubing of varying hardness (durometer) — from soft and flexible like PVC and silicone, to semi-rigid types like polypropylene, polyethylene, polyurethane and ethylene vinyl acetate (EVA). To accommodate these varying styles of tubing and their respective application needs, different connector types are used, including barbed connectors, check valves, Luer connectors, quick-acting couplings, threaded luer fittings, and tube-to-tube connectors. Of these, the most commonly used tubing connectors are tube-to-tube connectors, Luer fittings, and quick-acting couplings. These basic connector styles can cover a wide range of liquid and air applications in laboratory and industrial environments.
| Figure 4 — Plastic connectors afford designers and manufacturers a wide latitude of flexibility, such as with this latest generation of SCV Series check valves. |
Tube-to-tube connectors — a popular choice for applications that do not require the disconnection of equipment or parts at any point during production or use. Tubing connectors are available in many different configurations, sizes and material options to adapt different tube sizes or styles, reroute the flow direction without kinking, and act as a manifold.
Luer connectors — delivery systems can employ conical or taper seal connectors, called Luers, to link various system components. The male and female components of Luer connectors join together to create secure, yet detachable, leak-proof connections with no O-ring or gasket required. Luer connectors come in a variety of configurations adapting to tube connections, threaded connections (UNF, NPT and metric) and other Luer or quick coupling terminations. Some of those incorporate a tapered UNF thread, similar to a pipe thread, which can also seal on the thread due to interference on the pitch diameter, facilitating directional alignment with tees and elbows.
Quick-acting couplings — allow flexible tubing and equipment to be quickly and safely connected and disconnected. They may be preferred over general connectors for fluid control because they can incorporate built-in shut-off valves that prevent spillage, allow multiple disconnections and faster servicing.
Many of the latest quick coupling designs focus on the user interface and are equipped with intuitively simplistic thumb latch and side latch mechanisms to make handling easier in laboratory and industrial applications. Quick couplings mitigate the prospect of accidental misconnections and create quicker and safer device connections.
Barbs
Plastic barb-style connectors provide designers with a capability to accommodate the widest possible range of tubing properties and application conditions, including a multitude of configurations such as tees, wyes, elbows, and manifolds. Several barb designs are available — each with unique characteristics to tailor connection performance to specific needs — for handling assembly forces, tensile resistance and blow-off resistance without the need for clamps.
Barbs derive their holding capability by expanding tubing above its nominal inside diameter, creating some amount of interference for a secure seal and good mechanical retention. The tube expansion can vary dramatically, from lower profile, easier connections to much more aggressive interferences, depending on the pressure and tensile pull requirements.
The selection of the proper barb style is essential to the connector’s tube holding capability. The cylindrical surface behind the barb should allow the tubing to relax against the connector. In choosing a barb style, the barb chosen should be designed with a sharp peak, allowing it to “bite” into the tubing for optimal retention.
Many plastic connectors and almost all metal connectors use multi-barb surfaces, which usually produce an inferior tube connection and seal. Multi-barbs cannot create a sharp bite on the tube, which inhibits retention. Also, they do not allow the tube a chance to relax behind the barb, resulting in poor tensile pull strength. Multi-barbs are also relegated to a manufacturing process that leaves a parting line on the sealing surface, creating a potential leak path.
This is an inherent design flaw, yet all multi-barb connector designs, including metal connectors, display this liability. In fact, poor quality single-barb plastic connectors are also afflicted with a parting line, reducing the efficacy of the connector. A well designed and properly manufactured connector will incorporate a singular barb with no parting line, a sharp bite, and a clean sealing surface.
Design optimization
Many factors can reduce the tubing’s ability to perform under pressure including temperature, chemical degradation, mechanical stress, pressure pulsation, selection of connector type and barb design. The latest generation of plastic connector technology affords designers and manufacturers a wide latitude of flexibility to design and set up applications that custom fit to their specific needs. Some connector manufacturers, such Value Plastics, provide comprehensive design centers to help instrumentation and equipment manufacturers achieve the highest level of performance from their connectors. With good consultation up front on the designer’s application requirements and prospective off the shelf or custom solutions, the pitfalls can be avoided and optimal designs can be executed.
Benefits
Compared to metal, plastic connectors provide a considerable reduction in weight and improved flexibility with regard to the equipment they serve. Also, plastic quick couplings allow rapid and easy servicing and maintenance of assembly line equipment, filling, and packaging systems to limit system downtime and speed throughput. Color-coding on plastic connectors also makes for quick tube identification and reconnection.
The cost difference between metal and plastic connectors is a major motivating factor pushing instrumentation, equipment, and system designers to further embrace plastic connectors in laboratory and industrial applications. Plastic connectors, particularly when custom designed for the application, are more frequently becoming the preferred solution in industrial and laboratory settings, due to their overall proven efficacy.
Riley Phipps is technical and design services manager at Value Plastics Inc., Fort Collins, Colo. For more information call (970) 267-5200 or visit www.valueplastics.com.
