Is hydraulic hose too strong?
The conventional method of hydraulic hose construction may be overly conservative. If so, perhaps hose could be lighter, thinner, and more flexible without compromising strength or service life.
What is in this article?:
A basic hose assembly consists of fittings, a tube, reinforcement, and a cover. The reinforcement must provide enough support to keep the tube intact and support all the forces created by the pressurized fluid. The tube is a leak-free barrier that contains the fluid and is supported by the reinforcement. The cover serves the same purpose as our skin — to hold everything inside and provide protection from the ambient environment.
The hose segment must have fittings on both ends to complete the package. The fittings anchor the hose segment and complete the sealing system. The hose reinforcement reacts to the hydrostatic separating forces acting on the end fittings to keep the hose assembly together. In short, we can only speak about a hose assembly when we conduct the force analysis to organize the hose segment reinforcement design.
As an engineer new to the industry, I accepted the conventional approach to hose reinforcement design. Obviously, the approach has worked well. There was no reason to question the analysis. Then a concern came up. What would happen if we used a different tube wall thickness? The mean diameter of the reinforcement would be different, but the hydrostatic forces and the fitting’s nipple diameter would be the same. To a seasoned hydraulics guy, this didn’t make sense. What is going on? Maybe hose strength should be based on the nipple diameter instead of the mean diameter of the reinforcement.
Evans hose reinforcement analysis
Figure 1. This rendition of Evans’ free body diagram of a section of hydraulic hose shows that horizontal and vertical forces from hydrostatic pressure act at the mean diameter (Dm) of the hose reinforcement.
Colin Evans’ book, Hose Technology, is a respected engineering resource found in many hose manufacturing engineering libraries. Similar reinforcement engineering design approaches are repeated in several other resources. In Chapter 7, Evans presents a free body diagram, along with an analysis of the forces for the creation of reliable hose designs and manufactured product. Figure 1 is an enhanced rendition of Evans’ free body diagram model showing the forces H and V as acting directly on each braid strand at diameter, Dm.
Evans defines an axial and a radial force and designates them as vectors H and V:
H = P x Dm2 × π ÷ 4, and
V = P × Dm × L ÷ 2.
Where:
H is the horizontal (axial) force vector from fluid pressure,
P is fluid pressure (not burst pressure, Pb),
Dmis mean diameter of the reinforcement,
V is the vertical (radial) force vector from fluid pressure, and
Lis the pitch (lead length) of the spiral.
Because these are vectors, we can calculate the magnitude and direction of the resultant vector, R.
The Evans analysis defines forces based on the reinforcement geometry. This analysis has the virtue of calculating a braid construction that has been used for many years and has been used to develop a large body of hose length designs.
Evans concludes with the (hoop force) burst formula for braided or spiral hose:
Pb = (2 × N × R × sinϴ) ÷ (Dm × L)
Where:
Nis the number of reinforcement ends,
Pb is hydrostatic pressure at burst. This value is measured and verified by experiment,
R is the breaking (tensile) strength of the ligament, and
ϴ is the braid angle: arctan [ 2L÷ (π Dm ) ].
Questions raised
Here is the fly in the ointment: The horizontal force calculation is based on the mean diameter of the reinforcement. So what? Well, consider we have a hose tube with a nominal (tube) inside diameter of 0.25 in., and further assume a pressure of 1000 psi. If we choose a tube wall thickness of 0.030 in. or 0.050 in., how much reinforcement do we need to keep the tube from failing? Assume the pitch is such that the reinforcement angle is 54° 44´and further assume the hydrostatic pressure acts at the mean diameter of the reinforcement.
Evans’ solution allows us to estimate both the burst value and the force the reinforcement must support; that value is N × R. This is true for any pressure from zero to burst pressure. Why is that? First, we’ll rearrange the Evans solution:
P × Dm × L ÷ (2 sin ϴ) = N × R
Now we find that the product of N and R for the tube with the 0.030-in. thick wall is about 130.7 lb. For the tube with the 0.050-in. wall, the product is about 166.6 lb. Why should the thicker, stronger tube need stronger reinforcement? To find out, let’s take a closer look at the free body diagram of a hose assembly that includes the end fitting.
Discuss this Article 4
Anonymous (not verified)
on Nov 12, 2012
How well or poorly does Mr. Stroempl's proposal agree with physical testing?
Pete Stroempl (not verified)
on Nov 21, 2012
Dear Anonymous: Thank you for the question. The physical testing is left to the hose engineers. My article is proposed to correct a mistaken notion presented in the Evan's book. The article proposes to the hose engineer that the axial force is generated at the nipple and is reacted to by the reinforcement. It is proposed the "action" is not at mean reinforcement diameter but at the nipple diameter. The proposed analysis of the internal forces offers justification for constructing lighter and smaller diameter hose assemblies that safely meet the technical requirements. Thanks again. pjs
Alan Hitchcox
on Dec 12, 2012
We also have comments about this article in our Hydraulics & Pneumatics LinkedIn group.
Here is a link:
http://www.linkedin.com/groups/Retired-engineer-poses-question-is-40236....
on Mar 12, 2013
I do not think that this approach is viable- at least if there is a consistent neutral angle, as the author acknowledges is well known and has been verified with experimentation.
Here's my rational:
In the derrivation of end and hoop forces above substitute the true internal diameter (let's call it D_I). Now it stands to reason that the braid angle will continue to be related to the diameter of the reinforcement, D_M. Substituting these values and rederiving the neutral angle would give Theta = inverse tangent of 2*D_M/D_I. This would mean that the neutral angle would vary with tube wall and reinforcement thickness- if this theory is true.
The other factor which is problematic about this assumption in general is the idea that burst pressure is the primary factor which is limiting the performance capacity of hoses.
Food for thought.... YES!
Answer to reduce cost from hose designs.... NO! (IMO)
Post new comment
(optional)
