High-strength, low-alloy HS-50 high-pressure hydraulic tubing is for applications requiring DOM tubing that meets SAE J2614 specifications. Designed for higher system pressures, benefits of the tubing include reduced overall system weight, reduced fluid turbulence and flow velocity, improved fluid-flow volume, and reduced heat generation. The tubing features a 50,000-psi minimum yield strength, 72,500-psi minimum tensile strength, and 30% minimum elongation.
Plymouth Tube Co., (800) 323- 9506
