Hydraulicspneumatics 1915 Supercaddy3web
System Simplifies Hydraulic Tank Cleaning
Jan. 21, 2015
The versatility of the Super Caddy 3 makes it useful for any shop or large fleet operation.
Super Caddy 3 is a service tool that gives dealers and service center the ability to clean a hydraulic system efficiently and with confidence. It supports oil cleanup activities both in the shop and on-site from a service truck. The versatility of the Super Caddy 3 makes it useful for any shop or large fleet operation. It can be used to clean systems, transfer fluids, and certify fluids to a certain cleanliness level. On-board sensors provide particle count and percentage of water saturation while the Super Caddy 3 quickly removes contaminants from oil.
The Super Caddy 3 is a complete redesign of the previous Super Caddy model. New features include: reduced size and weight, improved filtration efficiency and dirt holding capacity, lower cost replacement filters, updated particle counter that can be recalibrated if needed, a new water content sensor, single lifting point, and the ability to operate at 120V or 240V with the flip of a switch.
Click here for more information, or go to click here to watch a video describing operation and capabilities of the Super Caddy 3.
Accumulators increase efficiency and provide smooth operation in hydraulic systems
June 10, 2011
Accumulators can increase efficiency and provide smoother, more reliable operation in hydraulic systems.
Shock absorbers
Jan. 1, 2012
The purpose of an energy-absorbing device is to stop a moving load with minimum load rebound, with minimum shock to the load, and minimum shock to surrounding equipment
