Series V080 and V130 mobile hydraulic directional-control valves can be configured with a full array of spool, control, and positioner options. Designed for flows to 60 gpm, the valves are designed for mid-range flow capacities in a compact package and constructed of cast iron with nickel-plated spools for use in high pressure application and can be configured with many different spool, control and positioner options.
Muncie Power Products Inc., (800) 367-7867
Click here to download a PDF brochure describing the V080 Series.
Click here to download a PDF brochure describing the V130 Series.
