Hydraulicspneumatics 813 Argo Hytosdgbiosen1 0
Bio-oil sensor
Aug. 13, 2013
The new bio-oil sensor uses an oil-condition sensor to determine which type of oil is in a reservoir.
The new bio-oil sensor uses an oil-condition sensor to determine which type of oil is in a reservoir. The sensor comes with a rechargeable battery and an optical display to help users determine the type of oil on site — mineral oil, mixture, or bio-oil. Two digital indicators also display permittivity and relative humidity. The case comes with an RS-232 interface for subsequent analysis and documentation of the data. Measured values can
directly be transferred to a PC for processing. Two different measurement methods can be applied: a quick determination or a detailed measurement and issuing of a value table.Argo-Hytos Inc., 419.353.6070, www.argo-hytos.com
Redundant sensor
Nov. 21, 2007
Temposonics MT magnetostrictive position sensor comprises a basic sensor element and evaluation electronics with separate output signal and supply voltage. Two sensor elements...
Important Considerations for Choosing Hydraulic Fluids
May 13, 2011
Stability, viscosity and corrosion protection protection are key considerations when selecting hydraulic fluids.
