The Hydraulic Calculator from Zanthic Innovations is a useful tool for anyone who designs or works with hydraulic circuits. This application provides quick and easy calculations for hydraulic components. Detailed calculations can be done for cyli
nders, pumps, motors, line velocities, line pressure losses and orifice pressure drops.
The calculator works on multiple platforms, including iPhones and Android devices, and provides necessary formulas right at your fingertips. Calculations can be done in both metric and imperial units.
Other apps are also available, including the Hydraulic Heat Calculator, to help in the design, troubleshooting and correction of heat issues within a system. The Hydraulic Tube Calculator helps determine tube diameter and wall thickness based on pressure and flow parameters. Finally, the Hydraulic Cylinder Calculator helps calculate areas and volumes within the cylinder. Extension and retraction forces, times, velocities, and outflows can be calculated.
A hydrostatic drive design app is currently in the works.
Visit www.hydraulic-calculator.com for more details or to purchase from iTunes and Google play.
