| One of the most recent products to integrate multiple functions into a single component is an accumulator charge valve (left) joined with a gear pump (right). |
The Haldex gear pump is said to operate at an overall efficiency exceeding 90% across rated pressure and speed ranges. Known for its reliability and durability, the gear pump's simple design also makes it a more cost-effective solution than alternative types of pumps, according to MICO's Dave Ewell.
The package greatly reduces the potential for leak paths by decreasing plumbing, which also makes the system easier and less time-intensive to incorporate into a system. Additional efficiency comes from the package's design feature that provides excess flow from the charge valve to operate steering, cooling, or implement functions.
The integrated accumulator charge valve and gear pump package comes with the option of single or dual accumulator ports with four charging rate options from 0.5 to 5 gpm. The unit displaces up to 1.4 in.3 with maximum continuous system pressures to 3000 psi.
For more information, call Dave Ewell at (507) 625-6426, e-mail dewel@mico.com, or visit www.mico.com or www.haldex.com.
