BV-10 system for threaded and flanged connections features high tolerance for reverse bending stress, sudden pressure increases, peak pressures, vibration, and temperature fluctuations. A 10° flared angle reduces stress and 24° cone connection with chambered soft seals provides nearly zero-leakage. Suitable for extreme loading. Easy assembly with thick-walled tubes. Compatible with stainless steel tubes with tolerances to DIN 2391-C.
Voss Fluid GmbH and Co KG, (330) 948-1641, www.voss.de
