Series 2.6 pumps come in a range of sizes from 19.6 to 39.8 cc/rev. Maximum speed is 3000 rpm, with flows from 15 to almost 32 gpm at maximum speed. Specifications include cast iron front and rear bodies, with the aluminum body housing compensation side plates on the gears. Shafts are available in tapered styles and the conventional 13 teeth SAE spline versions. Maximum continuous pressure ratings are 4500 psi for the smaller sizes with 3335 psi for the 32-gpm size. This new series of pumps is projected as competitive with fixed bent-axis style piston pumps used in mobile applications.
Integrated Technologies Inc.,
(800) 860-5597,
www.integrated-tech.com
