1. A check valve is a/an:
- directional control valve
- counterbalance valve
- reducing valve
2. Pilot-operated check valves have ___________flow in one direction.
- increased
- controlled
- decreased
3. Pre-fill valves have ___________ flow at low pressure drop.
- higher
- less
- the same
4. Pre-fill valves are used to:
- make small cylinders move faster
- give large cylinders more force
- fill and empty large cylinders quickly
5. A plain check valve can be used as:
- pilot-operated relief valves
- direct-acting relief valves
- either type relief valve
6. A 2-way valve has:
- one working port
- two working ports
- three working ports
7. A 2-way valve can have:
- two positions
- three positions
- four positions
8. One 3-way valve can power a double acting cylinder in both directions.
- True
- False
9. A 4-way valve has:
- two working ports
- four working ports
10. A 5-way valve is normally used in:
- air circuits
- hydraulic circuits
- both air and hydraulic circuits
11. Direct solenoid-operated valves:
- are only DC current activated
- are only AC current activated
- operate off either AC or DC current
12. Solenoid pilot-operated valves must have at least___________pilot pressure minimum.
- 25 to 50 psi
- 50 to 75 psi
- 75 to 100 psi
13. The X port on a solenoid pilot-operated valve is for external___________.
- drain
- pilot pressure
- either drain or pilot pressure
14. The Y port on a solenoid pilot-operated valve is for external:
- drain
- pilot pressure
15. Stroke limiters on the working spool of a solenoid pilot-operated valve can:
- slow spool travel
- speed up spool travel
- control actuator speed
16. A D10-size valve can flow up to:
- 80 gpm
- 90 gpm
- 100 gpm
17. This symbol is for a:
18. An open crossover (transition) valve blocks flow as it changes position.
- True
- False
19. Pneumatic directional control valves:
- are always subplate mounted
- are always in-line mounted
- may be subplate or in-line mounted
20. A series bar manifold can have as many as:
- one station
- two stations
- three stations
