1. A weight-loaded accumulator:
- loses pressure as fluid discharges
- gains pressure as fluid discharges
- stays at the same pressure as fluid discharges
Advertisement
2. A spring-loaded accumulator:
3. Gas charged accumulators use:
- oxygen
- nitrogen
- argon
4. The most common accumulator application is:
- supplementing pump flow
- making up for system leaks
- providing an emergency power supply
5. Precharge pressure should be checked at least every:
- one to two months
- two to three months
- three to six months
6. An accumulator may be used to:
- make a pump run faster
- make a valve shift more quickly
- make up for system leaks
7. Accumulator pre-charge pressure is normally.
- 95% of minimum system pressure
- 85% of minimum system pressure
- 75% of minimum system pressure
8. When the pump is running, an accumulator dump valve keeps fluid:
- from going to the accumulator
- from going to the circuit
- from going to tank
9. An unloading relief valve sends:
- pump flow to tank at system pressure
- accumulator flow to tank at system pressure
- pump flow to tank at 25 to100 psi
10. This symbol represents a:
- weight-loaded accumulator
- gas-charged accumulator
- spring-loaded accumulator
