Quiz on Chapter 17
1. Air-oil systems use_______for power and_______as the controlling medium.
- oil, air
- water, oil
- air, oil
2. Attached oil control units can control cylinder action:
- both ways
- on extension only
- on retraction only
3. Large-diameter air-oil tanks:
- increase pressure at the outlet
- decrease pressure at the outlet
- have no effect on pressure at the outlet
4. You should size oil-flow lines in an air-oil circuit for:
- 2 to 4 fps velocity
- 4 to 8 fps velocity
- 10 to 15 fps velocity
5. Tandem cylinders can be used in:
- synchronizing circuits
- circuits that require mid-stroke stopping
- two-speed circuits
- all of the above
6. The oil output volume from an air-to-oil intensifier is equal to:
- air input volume
- a large portion of air input volume
- a small portion of air input volume
7. Output pressure from an air-to-oil intensifier is controlled by.
- the area ratio of the pistons and/or rams involved
- the length of stroke
- the size of the outlet port
8. Air-to-air intensifiers:
- run continuously, regardless of output pressure
- stall when output pressure on the intensifier piston reaches input pressure
- stall when output pressure on the intensifier piston tries to go higher than input pressure times area ratio
9. Air-to-air intensifiers are good for:
- high volumes of air at increased pressure
- medium volumes of air at increased pressure
- low volumes of air at increased pressure
10. This symbol represents:
