1. Hydraulic oil is compressible:
- not at all
- by a great amount
- by a small amount
Advertisement
2. Viscosity is a measure of the hydraulic fluids:
- color
- temperature
- thickness
3. Synthetic fluids:
- cost more than mineral based fluids
- will not burn
- are compatible with most seal materials
4. The main purpose for hydraulic fluids is:
- to fill the tank
- to leak from every opening
- transmit energy, lubricate and seal
5. Over heating hydraulic fluid:
- makes it last longer
- deteriorates the additives
- makes it smell better
6. New hydraulic oil is clean to:
- 5 microns
- 10 microns
- 25 microns
7. Viscosity Index is a measurement of the change of flow characteristics of a fluid from one temperature another.
- True
- False
8. Hydraulic fluid should be stored:
- in a damp moist atmosphere
- in a closed and sealed container
- in an open container
9. A high viscosity number gives:
- better sealing characteristics
- poorer sealing characteristics
- has no effect on sealing characteristics
10. Refined mineral oil has:
- excellent lubricating qualities
- good lubricating qualities
- poor lubricating qualities
