The TP200 temperature sensor has built-in signal conditioning and provides 0- to 5-Vdc or 4- to 20-mA linear analog output. Simple two or three-wire hook-up eliminates problems associated with cold junction compensation, curve fitting, and typical thermocouple limitations. Available with either #4 SAE, 1/4 in. NPT, or 1/4 in. BSP ports. Temperature range is 0 to 150° C in a high-pressure, stainless-steel capsule rated to 6900 psi.
Webster Instruments,
(800) 932-8378,
www.webster-inst.com
