MT375-4 manual air valve bank comes with four 3-way valves, with spring return center and common supply and exhaust.
Compact design provides control to four single-acting air cylinders— ideal for mobile equipment. Machined aluminum body is black anodized; valve bores are hard anodized for long life. Spools are made of 360 brass. Buna N O-rings are standard. All ports are3⁄8in. NPT female; 1⁄8-in. NPT female ports are supplied for gauge pressure. Changes in the handle movement allows variable speed.
Technical Renovations Inc., (800) 299-7773,
Click here for more information.
