Long-life linear actuators are corrosionresistantand available in 1-in. bores in brass or stainless steel with a clevis-style tail. Piston rod is supported with two composite bushings in nose and tail assembly to support couples induced by side loads and stress reversals. This minimizes stress risers and failure. Featuring 0.78-in. extension and 0.70-in. retraction force factor, they are rebuildable and do not require lubricated supply air.
Beswick Enginering Co. Inc., (603) 433-1188, www.beswick.com
